BoatinSteve
I read these posts all the time, but this is my first request for help. I have a 1997 41 ft Silverton convertible with 502 xli TBi motors. About 3 weeks ago, I took my first real trip of the year... which was about an hour away from my home port. On my way home, at cruise speed (3200 rpms/20 mph) I started getting what felt like fuel starvation or a miss on my port engine. At lower rpms, it was okay. During that week I changed the fuel filters on my engine... the small racor and the metallic silver one just before the throttle body. I also cleaned the screen on the pancake filter before the fuel pump. On a test ride, I still had the problem... 3000 to 3200 rpms max under a load... I checked the distributor cap and pulled a couple of plugs and figured no matter what, based on what I saw, it was time to change plugs, put a new cap on, and rotor. didn't make a difference... I then checked the fuel pressure and on my starboard engine with a fuel pressure gauge. I had 18 lbs. of pressure. On the port engine, I had 6 to 12 lbs... So I figured, I found my problem and changed the electric fuel pump. $300 later, on a test ride, I still had the problem...3000 rpms to 3200 rpms and no more... Starboard engine was running great. Next step was to get a 5 gal gas can and bypass the fuel tank. I was barely out of the slip, and the tank was empty!!! wow! so I bypassed the port gas tank and ran both engines off the starboard tank... same thing... 3000 to 3200 rpms. No buzzers, gauges all read good. I've spoken to several locals and am being told its time to start switching parts like the MAP and TPS sensor from the port engine to starboard and visa versa. What a horrible way to try to fix a problem... There are no Crusader dealers in my area either. I have also been told that maybe I should pull the boat out of the water and that maybe there's something restricting shaft or prop... Please any real help at this point is really appreciated.
