markkingscraft
"My second engine starts - roa
"My second engine starts - roars to life actually - when accelerator pumped.
Runs great above 1500 rpm.
Lower than that it runs for a bit but slowly seems to run out of steam.
Will go at 1200 for a minute or two, then quits.
Lower than 1200 it just dies.
The engine is a rebuild. The carb was rebuilt although I opened it up today and cleaned some gunk out of the fuel bowls and blew carb cleaner through all the jets and checked the needles and seats and floats. All seemed okay.
I also removed the idle mixture screws and blew carb cleaner through.
New fuel pump and I get lots of fuel. Clean filters etc. Lots of fuel in bowls. Accelerator pump works wonderfully.
I have managed to keep it running at 1500 so I could preliminarily set the timing although at fastest run it is harder to re-start.
The AFB Carb has the large idle screw on the front and it seems to run best screwed all the way in, although I can run it at about 2000 with the screw all the way out.
However, I don't think this has been a fair check of the idle screw.
I haven't been able to adjust the idle mixture screws but have them set at two turns out.
At about 1400 with the flame arrester off, I slightly closed the choke and the engine sped up maybe 200 rpm. Close the choke all the way and it dies.
Do I have a carb problem or should I be looking at electrical? (Points are new, condenser I believe is new, cap and rotor are new, coil is new I think)
Electrical checks that I have done show good spark from the coil, decent spark at the plugs but I noticed that below 2000, rpm wavers as much as 250 rpm.
Unable to tell if this is electrical or fuel-related and of course I am getting frustrated running from the helm station to the engine.
Anybody have any ideas?
Mark"
Mark"
