D
Dennis B.
Guest
"Hey gang, have a 1986 318cu.i
"Hey gang, have a 1986 318cu.in. with top end power loss. I have replaced cap,rotor,plugs,coil and fuel filter. Ignition is a newer Mallory electronic (ie:no points). Old plugs were good color (80hrs.)Also replaced carb,Qjet needed rebuild but good price on Holley.Runs great to 2800rpm and then seems to go flat, Floscan meter shows fuel use (20gph at W.O.T.)Did the same with other carb on it. Have already checked under boat for marine growth and removed what little was there. Normal rpm at W.O.T. is 4100, best I hit is 3100rpm."
