318 different ring gears
xmarksthespot
"Drivin me nuts, just had a re
"Drivin me nuts, just had a reputable mechanic do a total rebuild on 318. Gave him a block connected to Borg 71 and V drive, block was no good so he used a block that was from a stern drive, bolted the flywheel housing and gear to it from the V drive, which has a rear mounted upper starter. The starter will not engage, it appears the ring gear is 1/2 inch low in diameter.So my long winded question is, are the ring gears diff on a 318 with a V drive, versus a sterndrive, and if so, where the heck do I get the right one. Now I gotta pull the engine again, arrrrrgh!"
"Captain Kirk:
Have Scotty fe
"Captain Kirk:
Have Scotty feed some more dilithium crystals to the hyper drives. You should be able to reach mach 5 with no problem.
sorry, I just couldn't resist."
"'Fraid so. (He should
"'Fraid so. (He should have test fired it on the ground. Bad mistake!)
Good luck, and be sure he does it this time.
Jeff"
"Jim,
With Borg or Paragon, C
"Jim,
With Borg or Paragon, Chrysler uses flywheel p/n 2846 924. The ring is p/n E7770M. The ID of the ring is 12.0 inch. The ring usually has the p/n stamped on the side. Other configurations use different flywheels and starters.
Good luck,
Dave"
