315 MPI down on power
Big Ged
Our mercruser is low on power and also sounds a bit tappity, could this be the problem, the motor has 60 hours on it it is a 315mpi
ta
Ged
Ayuh,.... With all the info you've provided,... It could be ANYTHING...
Try a Tuneup, 'n Filter change, then go from there....
Check compression, with all the plugs out on a warm motor, write down each cyl. numbers and what cyl'
Example: 1-150
2-151
etc.
