Hi , i gave the cylinder head and the new sleeves to the Caterpillar dealer in Jeddah got it back on the 6th day, fitted them and blew No 6 injector tip o ring tried again same same, on the third attempt at fitting the tip o ring, blew the 4 inch hose from the aftercooler , removed the Turbo and found the waste gate flapper valve rusted into place so removed the cover disks, removed the burst disk giving access to the mechanism drilled it out freed it up returned everything back the way it was, did some tack welding , and thank you god it is running like a sweetheart.
