M
Mikey88
Guest
"How do you remove the throttl
"How do you remove the throttle handle on a Quicksilver 3000 Classic shifter? I see a set screw on the bottom, removed that but no help. Does the handle supposed to pull off hard. Boat will not start, kill switch is in the run position, I wiggled the throttle handle and it started, I think I may have a problem with the neutral interlock switch but I can't get the throttle handle off to check if I have a bad wire. Please help."
