30hp upgrade
fvee91
Hi all, I have a 2006 30hp Tohatsu 2 stroke, think its a M30A? ANyway I have just fitted it to a new boat which is a bit bigger than the last one and it seems to strugle a bit. From what I can gather the 2 cyl 40hp engine is the same except for a longer stroke crank. So my question is, will the 40hp crank fit the 30hp engine?
Daniel
The 40C is a completely different motor -- different block and intake/exhaust parts, and the flows are entirely different in the intake and exhaust. Even if it would work mechanically, you would need a different carb 345032000M $193.07, and the crank kit 348000300M $772.27 -- I'm not sure the main journals would fit, either, and the runnability would be terrible. Are you sure you want to dump a thousand dollars (in parts alone) into this machine to produce a motor that runs poorly?
Hi Paul, thanks for your response. In answer to your question, yes I would happily sink $1000 into the engine because its a lot cheaper than buying a new 40hp! Why do you say it would run poorley? I cant imagine that it would run any worse than the standard 2cyl 40hp??ThanksDaniel
Daniel,
The thing is that the blocks are completely different, and the flows are completely different. Have a look at the parts catalogs and you will see what I mean. Any gasoline motor is essentially a pump, and flow is everything to a pump.
For example, if you put a "stroker crank" in a "grocery-getter" carbureted V8 car, and don't change the rest of the induction (carb/intake), exhaust, and cam/valve systems to match the increased volume, the motor will have worse runnability than if you had left it alone, and little power increase.
Same holds true in 2-stroke OB's. In your example, the block is different, the pistons are different, the crank is different, the reed block is different, the carb is different, (though they share a fuel pump), the magneto is different, the ignition advance curve is different, the recoil is different, the driveshaft housing is different, (though they do share a water pump), the LU is different, etc.
Just not practical or cost effective. Right now you have a 5 year old 2-stroke 30. If you were to replace it with a new 40, it would not be a 40C... it would be a TLDI, which is a completely different animal. Yes, you could hand build a whole 40C from parts, but the price would exceed the cost of a new TLDI. OTOH, if you locate a 5 year old 40, that might be reasonable.
Daniel
No, period.
