"I have aquired a 30ELO 689-l-
"I have aquired a 30ELO 689-l-418213 motor. I was wondering what year this motor was made. Also, what spark plugs are reccomended for this? It had been sitting for a while, so I took the carb apart and cleaned it. I noticed while it was running with the "muffs" on, that gas was leaking out of the top of the carb. Upon further investigation, there looked like a screw had came out. I found one and put it back in there. Since then, I have thought it might actually be a vent hole or something. Should there be a hole open on the left side of the top of the carb? It picks up and runs good, just a booger to get cranked. So, I guess my problem is should I "re-set" the float lower and take that screw back out (if this is a vent), and also, what is a baseline setting for the fuel air screw? Thanks for your help! Sorry for the long jumble up post.."
