"Almost completed reassembly o
"Almost completed reassembly of motor.No problems found right down to the block.All that is left is dropping the cap rotor assembly back down into the block.What is the easiest way to set timing as the lower gear has alot of teeth and then making sure i'm at top dead cetre.I have alighned the timing marks,but does that mean tdc.Thanks for any help."
