30 hp Johnson will not go into gear
K
Kent Burns
Guest
"I have a 1985 30hp Johnson th
"I have a 1985 30hp Johnson that has not been used for a few years and last month we got it out and got it working again, so we took it up north Mn. and my son was using it when he said it would not go into forward gear and by the time I got to him they could not use reverse either. When he showed me what was going on it sounded like it was grinding, trying to get into gear, so I told them to shut it down right away and we tilled the motor up then gear oil started to run out of a little hole on the side of the shaft."
"initially,....i would say u h
"initially,....i would say u have 2 prob's....shift rod,and gearcase seals....UNLESS,...he hit something...look at the prop.how is it?"
"The prop is fine, that was th
"The prop is fine, that was the first thing I thought of also. But I did notice some mud in the hub of the prop."
