D
Dan Hutchings
Guest
"Ok here's the problem. I
"Ok here's the problem. I have been running my 1991 Sea Ray once a week for the past four weeks. The last time I took it out I have had a problem. It will run good for a about 10 minutes at full speed and then will bog down and die. It will not restart until it sits for 15 minutes then it will restart and run for about 10 minutes and die. The problem is intermittent. The engine is not overheating. Prior to this problem I filled up the tank, and ran the gas stations pump dry. I have replaced the water separator, Fuel pump, in-line filter, coil, plugs, points, distributor cap, condensor, adjusted the carb, and checked the timing. I have taken it out on test runs and it will run great for about 10 minutes and the problem would start again. I have not solved the problem and I'm completely stuck please help."
