My father in law brought over a 1984 boat with OMC and 3.8 v6. We were cruising along, the boat was running like a dream. Cut through an area that we later found out is full of sand bars. In a no wake zone we were barely moving, the motor suddenly felt like it was bogging down, the bucked a little bit. We put it in nuetral, no issues. Back in gear, bucking and slowing, neutral fine, back in great a little bucking then the whole outdrive swung up then back down. We stopped the boat, waited and then headed for the dock (1/4 mile). Everything seemed normal. We pulled out of the water. My fatehr in laws friend said the outdrive is probably low on oil. We drained the upper unit, hardly any oil drained out, and about 1/2 cup of clear water came out. No mixing of the oil and water,
What lind of oil do you put back in? the manual only says OMC outdrive oil.
What would cause the outdrive to buck like that?
No sign of metal in the oil, the manual is not clear on how to fill it back up; it refers to a fluid lock, what the heck is that.
I really need some help here.. Thank you very, very much!
