forums.iboats.com
New anti syphon valveDid you check:
Anti siphon valve
Fuel pick up tube for crud build up if it has a screen on the end of it as some do?
Fuel tank vent
Fuel line from tank to pump?
I will try these tests thank youThe thing to keep in mind is that there are 2 separate systems, the engine fuel system and the boat fuel system (what I listed above). If only focusing on the engine fuel system, you can miss the actual cause.
other tests that can be done:
clear hose test, use a length of clear fuel hose in between the hose that comes from the tank (use a double barb fitting) and the fuel filter inlet. Run the engine and see if you see a steady stream of bubbles. If so air is getting pulled in, it could be a bad fuel line or even a crack in the fuel pick up tube.
fuel line vacuum test that can be done:
measuring the vacuum in the fuel line between the tank and the pump, this is more complex to do, you need a vacuum gauge and it has to be teed into a fuel line that gets connected between the line running from the tank to the fuel filter inlet. If the vacuum is higher than about 4" of mercury, you have a restriction, that could be a bad anti siphon valve or crud on the screen on the pick up tube if there is one.
it sounds like your fuel pump is OK, there is one last test you can do, disconnect the fuel line from the tank to the fuel filter inlet and hook up a vacuum gauge to it. Start the engine, a healthy pump will pull at least 9-10" of mercury on the gauge. Note that this is different than the fuel line vacuum test above.
when doing any of these tests be sure to be cautious about fuel vapors!
