2hp Evenrude carb adjustments.
Jerryjerry05
Outstanding Contributor
Working on the neighborhood kids 2hp Evenrude. It has 2 adjustment screws.
​Mod E2RCTD E0165053
The top is slow speed and bottom is high speed.
Any links on adjusting? Any help would be appreciated.
(Carburetor Adjustments - Two Adjustable N/Vs)
(J. Reeves)
Initial settings are: Bottom high speed = seat gently, then open 1 turn out. Top slow speed = seat gently, then open 1-1/2 turns.
Setting the high and low needle valves properly:
NOTE: For engines that DO NOT have a shift selection, obviously there is no NEUTRAL position. Simply lower the rpms to the lowest setting to obtain the low speed needle valve adjustment.
(High Speed) Start engine (it will run pretty rough), shift into forward gear, take up to full throttle. In segments of 1/8 turn, waiting for the engine to respond between turns, start turning in the bottom high speed needle valve. You'll reach a point whereas the engine will either start to die out or spit back (sounds like a mild backfire). At that point, back out the needle valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest setting.
(Low Speed) Slow the engine down to where it just stays running. Shift into neutral. Again in segments of 1/8 turns, start to turn the top needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running. Eventually you'll hit the point where the engine wants to die out or it will spit back. Again, at that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
When you have finished the above adjustments, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
All it takes is a couple drops of water to make you scratch your head with these motors. If you get it running good and it just dies it is likely water in the tank. What I do is just remove the high speed jet and drain the float bowl then preset the jet out 1 turn from lightly seated. It is real easy to dial in the high speed jet out on the water, but once you get the slow needle set just leave it alone just feather the choke until it warms up and stays running.
Thanks Joe and Kim.
It had water in the fuel and the boy who owns it started messing with the screws.
The water was the first thing I checked for.
Changed the fuel and sent him out.
Still wouldn't operate right.
Finally after talking to the kid I realized the thing was probably overheating and pulled the lower and it needs an impeller.
But he still messed with the screws and the info you gave will help get it running right.
Thanks,Jerry
