Hey folks,
I do alot of fiberglass ztuff here on the west coast of canada, vancouver island to be exact. Basically rebuilding any double eagle or hourston glascraft. They are staples here on the west coast.
Generally find garbage ones and full gut job. New stringrs , transoms , floors..
Ive bin posting all my builds on faceplant and am now doing custom jobs for people.
My latest job is a transom re and re on a mint 18.5 double eagle with a hoppin 350 4 bolt main, 290 leg.
Normally i pull the stern drive set up and pod the boats with this one exception.
I know the 290 is bullit proof, might be a 280 , not sure.
Its got the old mechanical tilt,no trim, system.
My issue is i dont want to dissesmble it till its all in good order cause when it all goes back in the boat will be spotless.
The motors rebuit and runs greT, the drive goes into fwd and rev, all is sound except the tilt.
The motor can be lifted to full up postion and the trim button pushed up to send plunger down, then push button to trim down and works fine, trim up and it works but starts making louder motor noises at about halfway up and stopz rising. If i get out and lift the leg manually and have a freind push the button i can zee the plunger go down and it will trailor home az such.
I have taken the motor out and it goes both ways. I have removed the entire unit and placed it aside and activated the swicth in both directions and it goes through full motion .
When it gets half way it gets real noisy.
I took the whole thing apart and everything was well lubed and the bearings were good.
Reasemmbled and again bench tested the entire unit.
I think the plunger proba ly travels a total of obout 8 to 9 inches.
Is that normal, if not what could it be.
