moresparks
I am currently undertaking the Biennial Bellows change on my outdrive and removed the drive to give a good overhaul and paint. I noticed that when I drained the oil it was very slightly coffee coloured. I put it down to the drain and fill plug seals!
I decided to do a pressure and vacuum test. I pressured up to around15lbs and this held for about an hour after this it lost around 0.5lbs an hour. The handbook says no more than the equivalent of 1lbs in 3 minutes. The Vacuum test was excavated to around 12in HG this held for around 15 minutes before slowly losing vacuum. This is still within the manual specification but not perfect. I have tested the tester and that’s o/k. But the loss is so small, the soapy water (pressure) and oil (vacuum) tests do not give a clue.
So… Should I worry? … I would appreciate any comments.
