After 2 years of just sitting unused and then a head rebuild I finally got the boat in the water to test. Everything worked well for a couple of days and until I started to get a intermittent vibration. 1/2 second vibration 1/2 second smooth running at any speed over 1200rpm. After pulling the boat I found the bellows full of water. It had hole in it at the top near the rear clamp. I did not find any water in the outdrive and will pressure/vacuum test it after it gets back together.
While I would like to pull the motor and replace both PDS bearings but no longer have a means in which to pull the motor. Is it possible to change just the rear bearing and seal from the rear? I realize this is not the preferred fix but it is what is possible at the moment. I have tried to separate the engine and flywheel cover in the engine compartment before and was not able to so that I not an option.
Should I replace the U-joint bearings as well? Does anyone have aftermarket part numbers for them? It looks like they can all be replaced without removing from the transmission with a bit of patience (hopefully)
86 Albemarle 24
320HP MPFI
290 flywheel cover
SP-A2 transmission
1.95 DP lower
86 Albemarle 24
320HP MPFI
290 flywheel cover
SP-A2 transmission
1.95 DP lower
