Ricardo,
Could you explain to me why at first you say the 2.14:1 ratio won't work but then say later that "The 4 cylinder transmission is the same gear reduction... so no issues there." Are they not the same? What are you calling the transmission? Is it the ratio of the gears in the "bullet" that is 2.14:1 and the transmission located in the upper housing? This is my first dealings wuith these outdrives and ratios and such. Sorry to seem like such a dummy. Lastly, if I stay with only a v8 package, do I definately need the 1.61:1 or are there otheres that will work if propped correctly? Where can I find the ratio on the outdrive?
Again, thank you so much for your input
It's all pretty much there in my first post.
Transmission = upper unit.
This is where the gear selection is made. With exception to the DP E transmission, all AQ series transmissions are of the same reduction.
This means that you can use a 4 cylinder transmission behind a V-8 and visa-versa.
Lower unit = the lower unit, or the bullet section as you called it.
Yes, this is where the "Over-All" ratio change occurs with this drive.
Ratio vs prop change! NO.... prop thrust dynamics do not usually allow for a prop pitch change to correct an incorrect ratio.
The engine determines the over-all ratio.
The 4 cylinder ratio is the 2.15:1 refered to as the D in a PZNR #
The V-8 ratio is the 1.61:1 refered to as the B in a PZNR #
There is also a 1.89:1 ratio refered to as the C in a PZNR #, and was used for the old inline 6 cylinder engine and for some V-6's.
If you remove the propeller and remove the ring anode, the ratio will be stamped into the aluminum prop shaft bearing carrier.
Wire brush the area, and it should expose the numbers.
This number will be good if no one has changed the gear set and forgot to re-stamp the carrier.
