B
Byron Hunt
Guest
"for Great site , it has been
"for Great site , it has been very helpfull in every aspect
i have a dual prop 290 and im getting serious errosion on my aft prop, it took about five years before it erroded all the way thru the aft prop blade right near the hub (all 3 blades)i had it welded but did not like the results so i purchased a new set fwd and aft prop to the tune of nearly 700.00 for just alum props.i replaced both props thinking that the nicks in the fwd prop were causing the errosion. well i have made about 4 trips since then around 400 miles total and my brand new aft prop is already erroding at the hub really bad and at even faster rate that before. is this nornmal ?? should i got to sst props (800.00 each) or is there some other situation that is causing this. i also have replaced all anodes as well"
