sandkicker
Outstanding Contributor
It's been an annoying problem for years and upon haulout yesterday, it rose to painful. For years, my drive kicks up when I shift into neutral while the boat is moving. Eventually, the drive "drops" (usually with a clunk) back into engagement with the transom shield. If I'm distracted or in a hurry ( like trying to dock in reverse in a cross wind) and shift in reverse, the drive kickes up, and then of course when I shift into neutral again, really "clunks". Once late this summer, I "overshot" the reverse to neutral shift and got a bit of throttle in FWD and it REALLY clunked. Admittedly, the shifter ( a circa 1969 MORSE single lever) is a bit "sloppy" and requires concentration. Since the drive does lock properly in REVERSE and not kick up if I engage REVERSE while the drive is down, I discounted wear on the "hooks" and weakness on the "springs" for the kickup @ the FWD to N shift while the boat it moving. The current prop ( soon to be changed to a 15x17) is a 15x19. I noticed in comparing the props that the difference in the "pitch" is no so much the blade angle (which I had assumed), but the "depth" of the blades, i.e., how far back the blades expend from the leading edge and also the amount of "overlap". For example, when viewed from astern, the 19" pitch prop shows "no daylight", while the "17" shows a gap between the blades, i.e., the trailing edge of one blade does not sweep back to "meet" the leading edge of the next blade. I realize that this effect directly relates to the drag that the prop induces on the end of the drive when I shift into neutral and hence the amount of upward rotational force on the leg if the boat is moving. So, my question... will my FWD into NEUT kickup resolve itself when I change to the 17 pitch prop or do I need to just replace the "springs and hooks" on the drive as well?
Also... It's been a few years since I took this area apart ( and I always did it while the drive was off the boat). Can the "hooks and springs" be replaced while the drive is on the boat?
OH.... the reason it went to annoying to painful???? I found the cross pin on the transom shield that the drive latches to... sheared almost dead center in the middle! Interestingly, the face of the sheared cross pin does not look "sheared", i.e. flow marks, but very rough, i.e., more like it was brittle. Will get a photo when next I'm @ the boat. Going to inspect the thru holes the pin sits in to make sure there isn't any damage to the transom shield itself.
