28 Johnson starts then stalls
VetteGuy
I have a 1987 28HP Johnson that will start and then stall. I have rebuilt the carburetor, replaced the fuel pump. If I push in the key for the primer I can keep it running. When it starts to die I push in the key and it will speed up for about 10 seconds then start to die again.
# 19 on the diagram you can use a welding tip cleaner or soft copper wire. Exactly how are you adjusting the slow needle? Did you put a new gasket on when you mounted the carb?
I thought I cleaned it when I rebuilt the carb, but I will take it off and clean it tomorrow. I did replace the gasket. I set the slow speed 1 and a half and then tweeked it after it started.
I did exactly like you said Kimcrwbr1 (clean #19 with weld wire) and that was the problem. It runs great now!. Thanks to all who took time out of your day to help me. Much appreciated.
