Tilt motor runs strong forward
Tilt motor runs strong forward and reverse but the outdrive doesn't budge. I removed the motor and confirmed that the motor turned in both directions. I can easily turn the worm screw shaft manually in both directions with no resistance. Does this mean that the worm screw gear teeth are stripped or is there another less expensive plausible cause?
