Hi All,
I had a oil leak into the yoke/u joint assembly bellow. I installed a new sealing ring # 839253 but it leaked. Which side of the sealing ring faces out- the flat side or the double lip side? I have a aluminum clamp ring with steel beaing insert with 2 thin shims and seal surface washer. How do I check for rolling torque value?
the gear that the hex screw bolts the yoke shaft too are even and the bearings seem tight- there is no movement in the yoke u joint assembly
however the other gears have a bright shine across the teeth with a little more wear toward the front/open point on the teeth? your thoughts please
thanks
tcmboat
thanks
tcmboat
