Thank you for the information, as far as what's wrong, the outdrive somehow leaked oil out and when I was cruising around 20 knots I heard a thump, I thought I struck something in the water. I put the boat back to neutral, raised the outdrive and there was no damage, that I could see. I started the boat back up and it would not go into drive. Being a distance from my dock I pushed on the throttle and it went into gear (not a good idea). It got me back to my dock and I couldn't get it back into neutral. Towed it to the ramp and brought it home. Went to drain the outdrive, nothing but water. The prop was seized and wouldn't move. Took the outdrive out and and went to turn the upper gear (where the u-joint is) and it would not turn. Disassemble the entire unit and the upper gear housing gears, seized, lower unit gears seized, middle housing gears seized. I sprayed PB blaster and got the lower unit gears to turn and also the middle gears to turn, (bearings feel rough, probably shot). I could not however get the gears in the upper unit (u-joints) to turn at all. So that is where I am at right now.
RicardoMarine, I am trying to better understand your reply, you noted that any 270,275,280,290 SP would work except a 4 cylinder because the final ratio is different, I thought the ratio on these drives were all the same? What I am trying to better understand is if I find any one of those outdrives you listed, would they work for me. If I find any of these outdrives that came from a 4 cylinder boat would they work.
