chrisclean
just bought bayliner cant get the stern drive to lock down , it will go up but will not lock down. Does anyone have any ideas as to what the problem is ? CHRIS
Hi Chris
Aside from this being a well covered topic elsewhere, I can give you some first hand experience. I have just had an exchange 280 drive (very similar to yours) put on my boat. The idiots I got it from supplied me with a drive that had come from a twin engine set-up and would have originally been a left handed rotation drive. These drives can be used in either rotation by simply taking the shift cover off and transfering the mechanism to the other side of the shift selector on the drive, but you need to be careful with regard to the gear shift selector in the cockpit. See your seloc manual for details.
However, the drive for my single-engined boat is right handed rotation, but the volvo penta main dealer, whom shall remain unnamed, did not spot that the replacement unit used to be a left hand rotation drive. They installed the gear shift mechanism in the wrong direction for reverse lock to work properly.
I.e. when I was going forward the drive was completly locked down (so if I hit an object it would not kick up as it was meant to) and when I selected reverse the drive would pop-up out of the water as it was not locked down. The reverse locking mechanism was operating the wrong way around.
If the boat is new to you, check out the set up on the gear selector at the rear and look to see if it matches your seloc manual diagram. Many of these older boats have had the drives re-built or replaced with nefarious components.
One word of warning, do not drive it in this condition as you could cause serious damage to the universal joint and drive coupling in the bell housing if the drive keeps kicking up in reverse. You will also not be able to stop in an emergency!! I talk from expensive first-hand experience!
Dan
Windy 22 Sport VP AQ200D 280 Drive
