Hypocolemicshock
Have this recurrent issue with my 1990 Crusader 270 with quadrajet carb and 1500 hours. It’s happened yearly the past 3 years and I’ve felt I fixed the issue then the next year at some point in the season it returns. Just trying to think of things I need to check while it’s on dry dock waiting for season in April. When running at 3200 rpm after about 45 seconds it will drop rpm to 2800 then 2600 and eventually stall if I don’t back off the throttle. I can run it at 22-2400 rpm after this occurs with no problems but as soon as I go back to 3200 rpm it will do it after about 45 seconds. When it does stall it fires right back up. No problems with my other engine and both utilize the same tank. First year it did it I changed the ignition module, seemed to fix it for about a year then it recurred. Changed plugs and put a new fuel pump in and problem seemed fix until the end of this last season. Changed fuel line and removed floscan from that fuel line as it is the only difference between the engines I can think of. Of course after doing that it ran the 8 miles to storage perfectly. My thoughts are that my “fixes” were just coincidental as they are different items but then the problem recurring almost a year later. Any thoughts on what else this could be?
