Hi All,
After being laid up for 1.5 years my Volvo 270 outdrive is not letting water up into the engine bay....
I have disconnected the hose from the transom and tried to suck water up through the outdrive, absolutely no give at all.
I have poured water down and blown down the outdrive and it wont let water back down it (is this normal, if so then maybe the non return valve is stuck closed?)
The impeller is sucking water fine from a bucket of water.
I have read the usual suspects are a rubber z pipe has a hole in it or the "elbow joint" is correded that the Z pipe connects to, but I'm not convinced this is the problem as either of these would let water out when blowing it through, no? (also no air is being sucked up through the outdrive either)
So I am thinking that something is blocking the water coming through? - Maybe pour some rubber friendly (if it exists!) drain de-gunker down it and blow harder!
Thanks for any help!
G.
G.
