Rick,
In the parts diagram
http://www.volvopentastore.com/Inte...on_id.640119809--store_id.366--view_id.784589 I do not see a washer for the nyloc nut. Are you sure there is one? I would like to get all the parts I need before I start the job. Thanks.
Some drive models had the washers installed new while some did not. Some to most (older) parts catalogs for the AQ series don't seem to show a washer but the later parts diagrams started to show/add the washers under the Allen bolts.
For example, take these two Intermediate Housing found in the following link below... The Intermediate Housing for the 270 Drive don't show the washers while the next Intermediate Housing down for the 275 Drive does show them as item number 15A.. < Which by the way is Volvo part number 942551 that you will need/want to order should you decide to follow the steps mentioned in the quote below taken from an OEM Volvo service manual covering AQ 280- DPC drive model.
http://www.volvopentastore.com/Tran...on_id.303964052--store_id.366--view_id.786368
Install the upper gear housing on the intermediate housing. Use new Allen bolts item 1, (2 pcs), Washers item 2, (2 pcs) and Nyloc nuts item 3. Many drives do not have washers under the bolt heads. When overhauling however, washers shall always be fitted. This applies to all drives. Apply some grease to the Allen bolt and stud threads, and to the contact faces of the nuts and washers. Tighten the screws and nuts in diagonal sequence and evenly all around and with a torque of 28 LB.FT Use tool 885008 and 885009.
Here's what the Volvo nut looks like if needed,
http://www.ebay.com/itm/941885-6-Nu...ash=item43b98704e3:g:snwAAMXQfFJROLgN&vxp=mtr
Not much info about the actual martial used searching the Volvo number 941885-6 like the Mercruiser nut shows below,
http://www.parttarget.com/5310-01-2...&searchoption=sku&originalsearchtext=941885-6
If interested to know, Mercuiser uses a copper/brass nut that's chrome plated. Merc part number 11-859116 Nut, Plain, Hexagon Material: Plastic polyamide locking insert copper alloy nut
Hardness Rating: Not rated
Thread Direction: Right-hand
http://www.parttarget.com/5310-01-5...16.html/-45D35C64-DAA5-4AAC-B528-F3A86BE5817D
Mercruiser's latest extreme grease ( 92-8M0071841 ) now covers a wide basis of areas.
http://www.michiganmotorz.com/mercruiser-high-performance-extreme-grease-p-3624.html
Calcium suflonate-based NLGI 2 grease
•Excellent rust and corrosion protection
•Formulated for high temperature and high load applications
•100% compatible with lithium-based greases
For use in the following applications:
•Steering systems/cable linkage
•Throttle and shift cables & linkages
•Drive shaft splines
•Gimbal bearings
•U-joints
•Suspension systems
•Chassis
•Ball joints
•Disc brakes and ABS applications
•Trailer wheel bearings
Replaces:
MerCruiser Engine Coupler Spline Grease - part #92-802869Q1
MerCruiser U-Joint & Gimbal Bearing Lubricant - part #92-802870Q1 & #92-802871Q1
MerCruiser Anti-Corrosion Grease - part #92-802867Q1
