There is some interesting info on the YLM as of lately.
I love the VR triggering of the YLM..... it is very hard to beat this "Variable Reluctor" type triggering..... Chrysler company had been using this for years, and very successfully.
The YLM 624 AV is for a LH Standard Rotation engine.
The YLM 624
BV is for a RH Rotation (counter rotation) engine.
Both distributors rotate CW, as the engine oil pump dictates this rotation!
The standard AV "drive" and "driven" gears place an
"Up-Lift" on the shaft (this is normal), and is checked via the thrust washer immediately above the driven gear.
However, the
BV "drive" and "driven" gear combination, places a
"Down-Load" on the shaft.
Apparently Mallory has an issue in-that the thrust bearing for the
BV is inadequate and/or is non-existent on this
624 BV model!
There have been some wear issues with
BV.
Apparently the YLM
619 BV offers the correct "down-load" thrust bearing, but the advance curve is not same as the 624, and would require a curve change, if I understood this correctly.
So, I would make a phone call to Mallory, or a Mallory dealer who is abreast of this, and find out what the fix is.
If a dealer knows nothing about this, then continue making calls.
I still think that the YLM is an excellent choice, however.
As for the Pertronix conversion kit, Jeff, you may not care for what I have to say about the Pertronix, but here goes.... no offense!
These kits are "Hall Efftect" triggering. The magnetic inducers are cast into a plastic unit that fits onto the existing points cam. IMO, they are not as accurate as a VR, for example.
In addition, we are relying on a retro-fit to our potentially worn shafts and shaft bushings and our potentially worn advancing mechanism, and so forth.
If the upper shaft area is worn, this may mean an un-wanted change to dwell while in operation.
(This isn't necessarily a hall effect issue, but rather an issue when using a distributor that may have many hours on it, and have some wear.)
Does the Hall Effect work? Sure it does...... but IMO, just not as well as a VR, or even a Photo Eye, (of which I would also steer clear of).
So if the budget is there, you can't go wrong by giving yourself all new components by installing a complete new ignition distributor..... Mallory or other! The advance curve should be very consistent between the two new 624's.
Set BASE,
check and adjust TA, and you're on your way.
Just my two cents on that!
