At the end of last years boating season I had two outdrive issues that needed repair. The first problem was that when shifting into gear, the throttle would advance too much before the actual shift took place. As a result there would be a slamming noise every time I engaged into forward or reverse gear. Problem #2 consists of an issue with shifting from either forward or reverse back into neutral. During that procedure, when bringing back the shift lever into the neutral position, it is usually necessary to go slightly past the neutral detent position for the desired shift to be completed.
A the start of last years 2015 boating season, I had a mechanic install a new short shift cable that goes into the outdrive. This spring I recently replaced the shift control box cables with new shift and throttle cables and adjusted the shift cables as per specification at the shift bracket. Before launching my boat I ran the engine and tested that the shifter worked several times, which it did without issue. I just launched the boat and confirmed that the slamming into gear problem has been rectified, but the Problem #2 (issue with the over travel/neutral detent position) has come back since the boat has been put in the water. What is left to check or replace? Would the switch on the shift bracket be a possible cause? If so how do I check it? Is there any shift linkage that could be worn inside the outdrive that can be causing the problem? Why is this happening in the water and not on land?
