Looking for some assistance as to "if" I have an outboard issue or I'm just being paranoid.
Before putting the outboard away last fall and getting it out this spring I started hearing a "whining" noise from the lower end after the motor is turned off.
I assume its the lower end gears continuing to spin after the motor is turned off.
I've changed the lower end grease but that looks clean. Should I be alarmed with the noise I'm hearing?
