hi i have a 2002 25hp 4-stroke
hi i have a 2002 25hp 4-stroke Bigfoot outboard that has no fire. i replace the coil which was not the problem. i have no power going to the coil unless i use the motor block for a ground. next i checked the stator mine has a plug with four wire and two quick disconnect plugs which goes to the rectifier but my model did not come with. back to the stator i test it out the White/Green and Green/White stator wire have continuity between it and the block ground if i check them one at a time using the block for the ground same for the other two yellow wires. i checked the other sensor thing that looks like a cam shaft position sensor from a car with two wires a red and a white i got a signal when i turn the motor over. it and the stator go into a Motorola (878433a1) ecu then two wires from it go two the coil i have unplug all the kill switches and still no luck can one help me please also the stator part number is 398-852386a6 which i can"t find it anywhere
