realjoe2000
"Could anyone set the record s
"Could anyone set the record straight for me? I have a 2004 25Mshc 2 stroke, 2 cylinder Yamaha with a bad rod bearing on the crankshaft. It developed a small amount of rust in the bearing due to what I think is a bad head gasket. Water in the cylinder. Is Yamaha and Mariner the same crank? Can anyone replace the rod and bearing on these one piece crankshafts? I cant afford a new crank and a used one is no where to be found ,so far. Can I look for a Mariner 2stroke 25hp crank? or is Yamaha the only one? I think I can get my outboard back if I can just find a solution to this crank problem. Thank you for your time."
