You should have received the "Operation, Maintenance & Warranty" manual with the motor and it will specify what oil the mfr recommends. I would use that oil on your almost-new and very expensive motor.
I seriously doubt that changing to the mfr's oil will do any harm to the engine.
I found this info on another site, sounds appropriate:
Effective October 2010, Mercury OptiMax / DFI or Quicksilver DFI 2-Cycle engine oil is the recommended oil for all OptiMax models - including Pro XS. (The previous recommendation stated the use of Mercury Premium Plus 2-Cycle Outboard Oil in ProXS models and OptiMax oil in non-ProXS models.)
OptiMax / DFI oil is a superior oil when compared to the Premium Plus oil. While both products are high quality 2-cycle engine oils suitable for use in OptiMax engines, the OptiMax / DFI oil contains a higher percentage of additives that reduce carbon deposit formation.
Over time, under normal operating conditions, carbon deposits accumulate in the power cylinder (piston, cylinder head, liners). In most cases the carbon deposits do not create a problem, but carbon deposits that form on the piston - particularly behind the piston rings and piston skirts - can reduce engine life and performance.
OptiMax / DFI oil is specially formulated to prevent the carbon deposits from forming. It also does a better job of reducing existing carbon deposits than the Premium Plus oil. Going forward, the Operation, Maintenance and Warranty manuals for OptiMax outboards will recommend Mercury OptiMax / DFI or Quicksilver DFI 2-Cycle engine oil to help maximize engine life and performance.
I expect your manual will say something to that extent as well.
HTH.........ed
