arkansashunter
!992 25 merc. Pull start only
What is the proper set up for the kill switch(es) wiring. I know that the bullet connector from the kill switch wires to the coordinating wire on the switchbox. My question is what is the proper wiring for the two grounds that are on the kill switch harness. I assume that they are just both screwed to the block in one of the threaded holes. Am i wrong on this?
I currently have the both grounded to the same bolt (the one mounting area where the rectifier would be on an electric start motor). Should they be grounded seperately, somewhere else, or do i need to do something else all together?
My motor quit firing so i took it to a mechanic and after the run around i just picked it up and all the electronics where in a box so i want to make sure i put it back together right so i can check to make sure the kill switches are working first.
Thank you
Thank you
