25 HP 2 Stoke died at full throttle
chris51478
Hoping someone may have a suggestion. I was out on the water today fishing and on returning to the launch i was at full throttle for about 10 mins when my motor started to bog down and start to slow, so i stopped, checked fluid levels and gas and all seemed okay. I then proceed to drive full throttle a few more miles no problem, then all of a sudden it bogged down hard and died, and will not start now. It is electric start and seems to roll over fine, just doesn't wanna start. i didn't hear anying break and it didn't make any weird unusual noises as it died it just quit. Going to have to take it too the shop after the weekend, but thought maybe someone may have had this happen and could be an easy fix, any help would be appreciated.
Check spark and compression,check fuel filter,check primer bulb and make shure it pumps up andholds pressure.mabe fuel pump went out?Good luck!!
I would guess that it is toast - no compression. When was the last time the carbs were cleaned, did you have fresh gas or was it last years stuff? Check compression - you more or less described a leaned out engine failure - hope its OK
