"Bought a boat from a guy I kn
"Bought a boat from a guy I know and the first time out it started fine. Then started having problems.
I took it in, and they said the starter was going bad, but it should last, and they looked things over and things were fine.
Problem is that it will start and run, then when I turn it off, and try to start again, there will be nothing (no gauges, or anything). If I let it sit for a little while, it will then start up.
Last weekend though I was out and turned the boat off, then it wouldn't start again. I had nothing for gauges, no other electrical up front. The only thing that works is the trim.
Got the boat home, took off starter and took it in. I was told the starter is bad, but I am suspecting something else. Checked voltage at coil, but didn't get anything, although I don't know if I am doing that right or not. I also checked the voltage at the fuse block up front, and there wasn't any voltage there. I'm wondering if the real problem is the coil. I checked voltage at the coil, and got nothing, but the starter is still out.
Am I right in thinking the coil is a problem? How would I check that without the starter being installed? Should I look at the solenoid too? Looks like I will also need to find a starter somewhere... only one I can find on Sierra Marine is for a 2.5 L. My Engine Model is #985683."
