23 Ford Engine OMC Fuel pump
stillafloat
I have been searching online f
I have been searching online for a fuel pump for my 89 bayliner capri. It has a 2.3 ford engine and is not listed on any site. All sites start with a 2.5. Any suggestions?
"Thanks for the information. I
"Thanks for the information. If I run into problems getting a new part, I will probably just put on an electric pump. Thanks again."
"Jason;
Will that work? Can y
"Jason;
Will that work? Can you really put an electric fuel pump on a 89 2.3 OMC (manufactured originally with a mechanical fuel pump)???
if so, what model would work?
Thanks."
"<[img]"http://www.marineengin
Cody i believe you just need t
Cody i believe you just need the same pump pressure and it should work if it is a marine style pump.
