"replaced spark plugs, points
"replaced spark plugs, points condenser, coil, plug wires, carb kit, have triple checked all components, engine was running before work, now only pops out of carb, have set distributor to #1 cyl, followed manual instructions, only thing noticed was when points removed #1 was pointing forward, now with setting as per manual #1 on rotor is pointing to #8, when I return distributor to original position backfires through exaust, verified timing with timing light light shows timing mark at 8 degrees, and rotor points #1 on distributor, have gone over this for 2 days now, also checked resistor wire 2 ohms
any suggestions"
any suggestions"
