225 stalls at idle
quo_vardis
"I have a 2000 model 225 Ocean
"I have a 2000 model 225 Ocean Runner which has recently started stalling at idle, it starts and runs fine and will run at idle while still in gear but as soon as you take it out of gear the motor stops.
It will start up straight away and usually idle fine until it has been in gear.
It did this on one outing and then for the next four days was fine, next trip out 9 days later it stalled every time it came out of gear.
Any ideas?"
"first ck shift switch
next c
next chg plugs,...when last properly tuned?--not just plugs...
decarb 1-2 x a yr."
"Thanks for that,
where is
"Thanks for that,
where is the shift switch located?
Plugs all changed at last service, pulled and checked last week and all clean.
Will try decarb as to my knowledge it hasnt been done for over 12 months."
"its # 98--------
<[img]"http
"its # 98--------
248475.png"" alt=""
"i am pretty sure this will be
"i am pretty sure this will be your prob...try to lube up the track it rides on,and wd40 the sw button....or,replace it...and lube.."
"ur u using QL78YC champion pl
"ur u using QL78YC champion plugs---gapped at --.030?
are u still on vro/oms pump--is so,drain carbs ck for severely blue gas..or color of your oil...u may have an oiling prob."
"Found out today that it was t
"Found out today that it was the shift switch sticking, once the replacement was fitted motor test ran fine.
