I have a 2002 Mercury Optimax 225. I am in Colorado. I have not experienced any problems using the motor and boat that I bought new in 2002. The engine has 365 hours on it. This year I have had into the local Mercury Dealer twice for problems. The symptom with the engine not wanting to start after being used for both approximately 10 minutes and after a half hour or so of operating (fishing, trolling at Lake Powell) problems. Both times I took the boat and into the Mercury Dealer the motor has started up just fine for them. The first time I took the boat and motor in (in May),they changed plugs, replaced the fuel separator, reported good compression and spark, said direct injectors were slightly out of spec, air tested "DIs" ??, as ok and verified fuels air pressure??. I used it June down at Powell for about 4 hours (over 3 days) with no problems. On July 2nd my wife and I took the boat back down to Powell. It operated fine the first day taking gear to the houseboat. The next day I tried to take a cruise to the Halls Marina and the boat would turn over but wouldn't start. It sort of kicked back so I left it alone and we used the trolling motor to get back to the marina and take the boat out and back home. I took it back to the local Mercury Dealer to see if they could find out the ongoing, intermittent problem. The battery was low so they charged it up They checked it out again. It started fine for them and no codes showed up. They said it could be that the battery didn't turn the motor over fast enough for it to start, however, I have run the battery dead with the trolling motor and then waited about 10 minutes then it just had enough chug to start the motor. I am puzzled as well as the technicians. Any thoughts from anyone as to why it runs sometimes and wont start other times?
