There are no Service Bulletins or recalls that cover that kind of problem.
It sounds like you are losing oil pressure. Is it leaking oil into the flywheel cavity? Is it safe to assume, that when you go into guardian mode, that the green oil light goes out?
They must have pulled your powerhead to be able to check the crankshaft end play. I presume when they removed the lower section of the engine, that they checked the oil pickup screen to assure it was not blocked with debris. I have run into this when the paper covers of quarts of oil came off when a customer was changing their oil. It all ended up clogging the screen in the oil pickup. It would be ok at low speeds, but when oil pressure was expected to increase, it did not.
I have not heard of this issue...keep in mind, I do not service a lot of 225's and have had very few problems with any of them that I do.
Checking your serial number...there is only three times recorded where there was warranty work done. This engine was built the first year that they were introduced. There were several Service Bulletins for various issues. These were probably performed, but may not have been posted to your engine's current record.
If you question the diagnosis, you could take it to another dealer for a second opinion or call Honda Customer Services. They may be able to check into how reasonable it is. I have no way to tell. Customer Service number is 770-497-6400. They act as an Ombudsman to check into your concerns.
I wish I could be of more help.
Perhaps someone else on the Forum have run into this trouble.
Mike
