225 4 stroke sputtering getting on a plane
jets1969
"had the mechanic change every
"had the mechanic change every filter, even swap computer stb to port, still sputters getting on plane and eventually stalls"
"Joseph, what ended up being t
"Joseph, what ended up being the culpret? I have a similar issue."
"Had the same issue - turned o
"Had the same issue - turned out to be a small air leak where fuel line exited an external fuel-water seperator. So, check for air leaks in the fuel line from the tank forward."
