Epicpopsicle
Hey guys. Having some difficulty staying on the water here's the breakdown. 351 ford dies after about 30 mins or so running as normal. I have changed the entire fuel system except the pump and tank. I have pulled the pump to check it out it was fine. The tank was opened and cleaned but I removed the check valve that was on it. Carb is a rebuilt one. It has a new coil. All the fuel lines and the filter are clear lines and I can see fuel moving along inside. If I run it in my driveway it runs forever but as soon as I put it on the water it will die after 30 mins or so I wait 5-10 mins and the cycle repeats any suggestions.
