Hello all,
I have a 2009 20hp Tohatsu that I tried to get running for the season after sitting idle for about 18 months.
When put into storage, I used fuel stabilizer and also ran the engine to use up all remaining fuel then fogged the engine.
The engine started up no problem but will not idle without using the choke. When using the choke, it will idle rough but it will idle. I then slowly push the choke in and the idle will raise and the engine will smooth out then stall.
I pulled the carb and intake off and the carb is spotless inside with all jets clear. The intake gasket was wet through the entire width of the lower section of the gasket.
That is the only thing I could find.
Does anybody else have any ideas?
Also, I did not remove the plate on the top of the carb, only the lower bowl.
Thanks for any help that you are able to give.
