20hp idles well but stalls
B
Biff block
Guest
My old merc will idle well but
My old merc will idle well but as soon as I put it into gear and put a little throttle to it it stalls out. Any Ideas?
"Biff,
You should check the
"Biff,
You should check the compression first.
If compression is good, I would suspect either a clogged carb or weak/no spark in one cylinder.
Tony"
