Trying to determine if the throttle lever should come into contact with the stop when wide open throttle is applied at the binnacle. The photo is of the throttle lever on the port side of the outboard. The Philips screwdriver points to the gap at WOT. If the throttle cable from the binnacle is disconnected, the throttle lever will contact the stop. 22 foot Aluminum boat with console. Dry weight 2000 pounds. 15.3 x 19 aluminum propeller reaches 5200 RPM at WOT. Engine specification is 6000 RPM at WOT. The math would tell you to put on a 15 inch propeller but that is believed to be highly questionable. Any insight would be appreciated.
