2023 Mercury Water impeller issue after installing.
stockburn
Engine 2023 Mercury Outboard serial 3B292282. 75 hp 4 stroke ELPT EFI 2.1 liter. Just replaced the water impeller and reinstalled lower gear case. I always leave helm in neutral. After install I checked the helm and it wouldn’t shift into any gear. During installation of lower gear case I used the propeller to help align the driveshaft. I sorta assumed it must have been in gear in order to move prop. I can’t figure how I jammed the gears. Is there a fix? I tried to move the gear selector into neutral but noticed it would slowly spring back into either forward or reverse. I could hold the selector in neutral and turn the drive shaft clockwise to proved it would go into forward and reverse. What can I do? I am at a loss.
