2023 90hp constant alarm
ffgomer
This morning I was out crabbing and the alarm came on for my motor. The odd part was that it was a lower volume than the alarm that beeps every time you turn the ignition key. I checked my VesselView app and it showed no faults. When I turned the keep back on I got the normal high volume alarm and then the low volume one came on again and stayed on even without the motor running. I stayed out on the water for a little while longer and had no performance issues but the alarm will not turn off. It is on whether the motor is running or not. Oil level is fine, engine temperature is fine. I did notice that the oil temperature showed a negative number. Could that be the issue? And if so, what would be the fix? I’m trying to avoid taking it to the dealer if I can.
I’m wondering now if it has nothing to do with the motor. As I posted, the volume was way lower than the normal engine alarm. Later yesterday I went outside to check something and when I turned the key on the constant alarm was still there but barely audible and started to fade out. I’m thinking there may have been some stray voltage that was causing it. I did have a fair amount of water splash into the boat yesterday so maybe something got wet and was causing continuity? When I get home this afternoon I’m going to check it again and see what it’s doing now that it has had a hot day to dry out.
